factory radio
Ky'sCRX
how do you take the factory radio out of a 97 gsr. i have to get the serial number so i can get a code to unlock it. any help would be great
take it out with magic hahahaha you'll have to go buy a peice it's a aluminum peices to take it out with
like i said i have never done a gsr but normally there is one on both sides but with ford trucks there are two on each side. so make sure you push all posible clips.
there are 2 little bolts on the back of the radio. you may need to remove the center console... unscrew the bolts nad it should slide right out.
