fan wont turn on
Discussion in 'HYBRID -> ED-EF / DA' started by lizoyd18, May 21, 2007.
  1. lizoyd18
    lizoyd18 Junior Member
    i just put in my zc and it is overheating my fan wont turn on its getting power and we tested it and it works, is it the ecu not telling it to turn on or is it the wiring . can anybody help me with this?????
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    could be a bad fan switch - unplug the fan switch connector from the back of the block, turn ignition switch on and connect the 2 wires in the connector together - the fan should come on - if it does, then the switch in the block is bad
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    or the fan could be bad run a wire from the fan straight to the battery to see it it comes on
  4. lizoyd18
    yea i tested it on the battery it comes right on
  5. lizoyd18
    so if it does work i should hook up the wired or the ground wire to another place right???
  6. AHHVTEC
    Alabama
    have you tried the fan switch yet
  7. jlicrx
    Colorado Springs
    if it comes on when you connect the wires together, replace the switch in the block
  8. lizoyd18
    its not good if the fan is on all the time when i turn the key on it stays on all the time but ill try what u said
  9. 91HatchBoy
    91HatchBoy New Member
    Olympia,WA
    hey i have the same problem with my car...all you need to do it hook up a toggle switch to the fan
  10. eg6sir
    and know when to turn your fan on
