Farewell MY CRX. Toasted
Discussion in 'Auto Multi-Media' started by erikespo, Sep 3, 2005.
  1. erikespo
    erikespo Senior Member
    Western New York
    I lent my CRX to my brother who need to drive to a city that is about 80 miles away and back. I say sure. On his way home he is like " Your car is running like crap" I already knew that. Little did I know...
    ...video of the crapiness
    I knew it was coming.
    BTW the host is slow for that video
    The car sort of laughs at me at the end. Speaking out its intake manifold.
    And incase you were wondering the throttle is floored from the start
  2. YouKnowWhoIBee
    YouKnowWhoIBee my avatar is better.
    Maryland
    did he run with no oil?
  3. erikespo
    Western New York
    Probably. I think it needed oil before he left and then didn't get any till 100 miles later. He was probably reving it to high.. I tell him keep it under 3k
  4. erikespo
    Western New York
    Well I am definatly in the market for a car, as tonight I just had to burn 12 hours personal time and that just gives me 24 hours to find a car before tommarrow's work day starts
  5. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    wow that sucks.....
    Why dont you just get another engine..? :)
  6. erikespo
    Western New York
    Because it will take time to locate another engine. by the time i get it and swap I will have just wasted money that I could have used for a real swap like a b18.
  7. Estorvito
    Orlando FL
    well...I sell you mines....
    Edit: Its a obd1 b18b by the way...I will hook you up with the gsr tranny because the one there is auto...<---But thats going to cost you....a little more..
  8. erikespo
    Western New York
    how much for the engine and tranny?
  9. Estorvito
    Orlando FL
    I will PM you in a minute....hold up....
  10. erikespo
    Western New York
    And and in the video the throttle is floored
  11. Estorvito
    Orlando FL
    wow ,,,hey i forgot to pm you..lol
    Make me an offer.... PM'ed you with my number,.....
  12. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    Holy shit, it really did laugh at you... I say keep it, any car with that much personality deserves another chance!
  13. brian11to1
    brian11to1 Senior Member
    :withstupid:
  14. erikespo
    Western New York
    Yeah I am going to keep it. I just need to gather everything the a b18 swap
  15. erikespo
    Western New York
  16. Celerity
    Celerity Well-Known Member
    Your timing slipped a tooth. IF you manage to run the car like that, I'm willing to bet the pipes will get RED hot in about 25 seconds.\
    I wouldn't say it's "replace the engine" time, unless your valves are gone too. Or, unless you have a swap in mind :)
    -> Steve
    I've had two engines slip a tooth the past 12 months - One, I built with the timing off (Ooops) and the other because the timing belt went. The Civic (WithDPFI) even looked and sounded like your video.
  17. erikespo
    Western New York
    Hmm.. I will try and adjust it back which way should i adjust the cam gear.. to the right 1 tooth or to the left?
  18. MugenCRX
    MugenCRX Senior Member
    Thornton CO
    Look at your cam gear. There is an arrow that tells you where top dead center is.
  19. erikespo
    Western New York
    I adjusted the belt 2 teeth backward. (toward the firewall).. it seemed to help but very little (I could rev it to a max of 3) but then wouldn't again start. so I put it 2 teeth forward to it original spot and i could do the same (rev it to 3k) but it sputters and dies. So I don't think it is a cam timing issue.. sounds more like ignition or something.
  20. Celerity
    Whenever a timing belt slips on it's own accord, then you can expect that the cam gear has moved FORWARD (So that the belt itself is retarded hopelessly backward).
    Move it 1 tooth forward, not 2. Or, if you want to stop futzing around, remove the wheel, plastic cover, and actually USE the timing guides found in the engine pulleys and repair manuals.
    All of this is well worth the effort - Take your time and start simple. Inspect the distributor input shaft (The keys can break off) (Although, it wouldn't start if BOTH keys were off) (My Civic a while ago had one key broken, and it was shift all around), then remove the cover and lash the valves (What I'm doing for the rest of the day today) and then work over to the cam gear. You'll be done with this in no time.
    -> Steve
