When ever I accelerate an any gear, it feels like I am getting tons of wheel hop. I have not a clue on what it could be. I just got the brand new Megan suspension put in with the Skunk2 camber kit. I have different opinions so far and need other input. It might be a wheel out of balance, the diff. not hooking up, or even a bad coilover. I believe it is coming from the passanger side in the front cuz when I have somebody with me it is not as bad. Any other things I should look at. Think the suspension is to soft or am I just retarded.
Check your front bushings and motor mounts(mainly the front/rear torque mounts). They're known to wear out especially in older cars.
i know exactly what you're talking about.. i had busted the motor mount bolts off in my block.. driver side mount only.. mine was bad though..
