fiberglass
4DRonDUBS
I had a wheel well that was dented in on my 92 civic 4dr so i filled it with fiberglass it looks ok but their are small holes in it how do i get rid of these wet sanding? also i have some miner rust under the wheel wells and on the little lip if the wheel well next to where the bumper attaches would spray undercoating work on this to help stop it? i heard their is anti rust gel that stops rust also anyone have any ideas
rust is like cancer it wont stop unless its all taken out. and there is a putty to put in the little holes. you could get it any body shop supply store and any autozone will have it
first sand down the glass then use a body filler on it then use glazing putty ass for the rust the only way to really get rid of it is to cut and weld buit a good temp soluition is a product called rust kill
