34diesel34
Import Tuner
I have a fidanza flywheel, and I'm about to put the pilot bearing in it. Looking at the fidanza flywheel it looks like the pilot bearing goes in on the backside of the flywheel (the side facing the engine). It will not go in on the front side of the flywheel (the side facing the transmission) because the hole is too small for the pilot bearing to go through. Does anyone know if this is the correct side of the flywheel to tap the pilot bearing into? The picture in the haynes manual show the pilot bearing being tapped in on the front side of the flywheel ( the side facing the transmission). Can anyone confirm that the pilot bearing is tapped in from the backside on fidanza flywheels, and from the front on stock flywheels ?
