I am going to do my swap next week. I have a 1995 Honda Civic CX hatch. I am swapping a B18B Ls.
I have all the motor mounts from the ls, i use the front and rear tranny mounts from the civic correct?
I need to change the o2 sensor to a 4 wire? if so how do i wire this up?
can i use the Civic wiring harness? my ls harness has been cut
i use the ls drive axles
i use the ls ecu
i use the ls throttle cable
i use the ls shift linkage
which radiator hoses do i use? civic or integra
Any other good information????
i use the ls ecu
