Wouldn't a single unit be the sum of the partsQuoted post[/post]]
The engine needs to be treated as a single unit rather than the sum of it's parts.
Quoted post[/post]]
and i never said you can tune really good with just a chip <--which isnt a tunable part(its pretuned) and a FR. thats ridiculous....you might as well leave it alone.
Quoted post[/post]]
ONCE YOU BURN THE CHIP ITS PRETTY MUCH NON TUNABLE...OF COURSE LIKE YOU SAID YOUR USING HONDATA OR ECU SYSTEMS LIKE THAT. EVEN IN THAT CASE YOUR NOT REALLY TUNING A CHIP YOU HAVE A FULLY PROGRAMABLE COMPUTER. I MEAN I CANT PLUG SOMETHING INTO MY SKUNK CHIP AND MAKE ADJUSTMENTS UNLESS I HAVE ANOTHER CHIP BURNED. THATS WHAT I WAS SAYING.
Quoted post[/post]]
you tune afr first. if your a diy tuner, you can do this without a dyno provided you have a wideband o2 sensor, tuning program like crome or uberdata, and a chip burner. but with more aggressive cams, you can benefit from tuning the cam timing too. you really have to do this on a dyno so you can see what difference its making on the power.
bambam said:I'm sorry, but imma call bullshit on this one. There's no way you dynoed a B16 with that much torque. I've seen fully built B16's put down less torque. Post a dyno sheet pal.
All you have is an intake, header and exhaust. Those cams don't give you that much HP with that low of compression. You can't be any higher than 10.6:1.
As for Stock B16's putting out 145....that's a healthy ass motor. You'd be lucky to hit 140 w/ all the bolt ons.
What are you using for tuning? I'm sorry, i just don't believe this. how high are you revving? because those cams don't make any power till almost 8k RPM and you have a stock computer? where did your power and torque peak at?
I work at an Import shop and I've NEVER seen a B16 dyno that high even with serious mods.
