Finally get it running and...
Discussion in 'HYBRID -> EG-EK / DC' started by slammedhatch93, Sep 25, 2006.
  1. slammedhatch93
    slammedhatch93 Junior Member
    93 civic civic b16 sir obd1 motor/tranny
    So I have had my car running for a week and blew the tranny since my friend forgot to put in fluid... then I throw in another tranny and drive it for 2 days until a hole appears in it the size of a baseball... Finally get another tranny installed today, double check everything I take it out on the road and baby it through first and second then I hit the gas and rap it up to 7g's real quick. (pop) Backfire??? Then the car dies, So while I am still moving I try and start it back up and it won't start back up. It's trying to turn over it sounds like, but wont. I checked the ground on the starter and every other wire I could think of, but couldn't find anything other than the o2 sensor was loose. The car still won't start up. The timing belt is still tight and looks good... maybe I blew my motor??? Any ideas???
  2. h46it
    h46it Junior Member
    Have you looked at the spark plugs? That can give you a good clue to see what happened to the engine. If they look good, try a compression test or leak down test.
    Hope that helps!
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    Are you getting spark?
  4. slammedhatch93
    Not seeing any spark so the dizzy must be dead???
  5. TurboMirage
    not so much the dizzy but the coil.
  6. slammedhatch93
    So I pull off the dizzy and pull off the cap and plastic peices fall out with the rotor screw... hmmm yeah replacing parts... Thanks GuyS!!!
  7. VTECin5th
    Phoenix Az
    Good job, the reason I asked is: we had a similar issue and it was the distributor.
    Hondaswap kicks ass ^_^
