Finally got Finished With Uberdata Install
Discussion in 'ECU's, Electronics, and Tuning' started by fast4u1991civic, Jan 18, 2005.
  1. fast4u1991civic
    fast4u1991civic Junior Member
    Well I finally finished chiping my ECU with Uberdata 1.65r3 and I also got my FTL (Full Throtle Launch) working. I stage at 5000 rpm and redline at 8000 RPM now. Video's Below. I also got my idle fixed, ever since I converted the car to OBD1 and did the Mini-me swap my idle has always pulsed. Im so happy I have Uberdata, its just as good as Hondata, has all the same features and it only cost 20 dollars in parts because the software is free.
    900 RPM Idle
    Full Throttle Launch 1
    Full Throttle Launch 2
    Full Throttle Launch 3
    Full Throttle Launch 4
    Full Throttle Launch 5
    Full Throttle Launch 6
    Full Throttle Launch 7
    Sorry about the squeaky breaks...
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    nice!
    nice j-turn also.
  3. 92civicb18b1
    92civicb18b1 The Trisexual
  4. projekteg
    projekteg Senior Member
    good thing your clutch is toast or you'd be spinning through 3 gears with ftl set that high ;)
  5. phunky.buddha
    Dallas / Fort Worth, TX
  6. fast4u1991civic
    LOL. Ya my clutch is gone, centerforce can suck my a$$. Thats the only reason I have it set that high and I was also just playin with settings.
  7. cxjon
    cxjon Senior Member
    man+k+toe
    are you using a wide band, also your fogeting the eprom burner
