Finish swapping GSR motor into EK need help
Discussion in 'HYBRID -> EG-EK / DC' started by racersky, Jun 2, 2006.
  1. racersky
    racersky Junior Member
    Alright I finish doing the swap into an ek but now I was wondering how do i get the power steering and a/c to work? What power steering line would i need to get this thing to work and also what parts will i need to get the A/c to work thanks
  2. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    I did a B16A in my 97 Civic and to get the power steering to work, I just got the B16 power steering hose (that was cut) and had it braized onto my stock hose. Worked perfectly. I eliminated my A/C, so can't help with that.
  3. GSRCIVICTN
    GSRCIVICTN Lost in a sea of rednecks
    Nashville, TN
    I believe your stock a/c can be retained on that vehicle by using a DOHC Del Sol's compressor bracket or one from a CRV.
  4. racersky
    I'm confused as to what you said.....so if i wanted to get the power steering to work i would need to get a gsr power steering pump and then get a b16 power steering hose and cut it and then have it braized? what's braize?
  5. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    no, keep everything you already have in your car. keep the same pump, keep the same hoses, keep the same belts, etc. the only things you'll change are the brackets that bolt the p/s pump and the a/c compressor to the block. use the brackets from a Del Sol DOHC Vtec.
  6. racersky
    Yeah but when i purchased the car before the swap the guy literally cut my factory lines in two which is no good for me at this point....is there any way i could get another power steering line? Which line will i need and also where can i get delsol power steering brackets from?
  7. GSRCIVICTN
    Nashville, TN
