Firing Order
Discussion in 'HYBRID -> EG-EK / DC' started by breakdancingbob, Mar 25, 2003.
  1. breakdancingbob
    breakdancingbob Member
    what order does the plug wires go on the distributer
  2. paragus
    paragus Senior Member
    rriiggghhttt.. it would help if you said what type of motor this on... we talkin s2k?? gsr? lude? etc..
  3. breakdancingbob
    oops. b16a first generation.
  4. Kakarrott
    Kakarrott Member
    it is 1 3 2 4 ((((( bottom left is1 )))) ((((upper left is 3)))) ((((( upper right is 2))))) ((((lower right is 4))))
    im pretty sure cuz im putting mines together to and i have the service manual . if u look straight at the distributor in that order hope this helps :)
  5. HOOKUPSPROCRX
    HOOKUPSPROCRX Member
    upland ca
    yes he is correct. staring with the bottom left and moving in a clockwise direction
    1-3-4-2. and on the valve cover star at the timing belt and go twords the distributor #1 is closest to the timing belt
