First Gen B16 help
JDMified
My buddy got a really good deal on a first gen B16a and wants to put it in his 93 Civic Si. I'm told the easiest way to make it work is to use an OBD0 harness with the OBD0 B16 and wire it into the OBD1 harness. Will most everything plug in or do I need to do a crap load of wiring? ANY help would be apreciated greatly! Heres what his need to buy list for thwe complete swap so far is:
First gen B16a
Hydro tranny
OBD1 Distributor
94-01 Integra rear "T" bracket
9?-?? Integra shift linkage (or stock modified?)
Second gen exhaust manifold with 1 O2 sensor
Quoted post[/post]]
First gen B16a
Hydro tranny
OBD1 Distributor
I've not done this swap, but i think you could use the Si wiring harness, and change the dizzy and injectors to obd1 if needed (alternator too)
The rest is correct, and 94++ integra shiftlinkage will work.
Quoted post[/post]]
ya use the si harness with obd-1 dist., injectors, and alternator. then get a obd-1 p30 and haul ass.
