after installing my ecu/ obd1 dizzy(td44-obdo plug)/ wideband o2 the car is running crazy rich and is chocking.
when i try to accelerate it stumbles up to 3K(limp mode?)
im guessing my injectors are doing this all i could tell is they are keihin's
what modes your engine got??? is it stock???
1st: Make sure u have a stock B16 map loaded in S300 and if it is and it still runs rich(which it shouldn't on stock engine) than take some fuel out make it about 14.5-15.0 AFR at idle its easy to do since u have wideband and S300
2nd: if other than stock injectors(there is no point in bigger injectors unless u turbo or s/charger with more than 8lb of boost) u have to enter resistance and cc of injectors in S300.
but to get it right under acceleration thats would be pain without dyno but its doable but u really need to know how to work with S300
Check Engine Codes? Motors don't limp for no reason.
Why are you running the S300?? If you don't have a considerable amount of modifications done (i.e, built top end minimum) then the ECU is worth more money in your pocket than using it in your car.
