first swap B16A
Discussion in 'HYBRID -> ED-EF / DA' started by whiterice91, Feb 25, 2008.
  1. whiterice91
    whiterice91 New Member
    im just wondering if it would be a terrible idea for me to put a b16a engine and tranny into my 91 civic hb myself, or should i get a mechanic to do it, im sure i am capable of it, but i dunno mabye its quite complicated let me know thanks.
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    it all depends on your capabilities....its really easy to pull the old motor and put the new one in..the only trouble is wiring
  3. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    If you have an si model then you only have to add 4 wires. Any person should be fully capable of doing that.
  4. whiterice91
    its a 91 std (4 speed, with a 16 valve d15b2) how many wires do i have to add for that because wiring was the main thing that worried me, also where do you redommend i get teh engine, im sure you guys have been to the jdm websites posted on hondaswap so would it be wise to buy from there or any advice on buying?
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
  6. whiterice91
    alright, im sure i can manage that, but stupid question... where can i get this stuff?
    1 black OBDo ecu connector with pins
    1 OBDo MPFI engine harness dizzy plug w/wires
    1 MPFI ecu
    1 injector box (with enough wire to solder to)
    wire close to factory colors as possibly
    assuming this wiring method applies for all 91 civic models including the std
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    junkyard..look for a 1990 integra
  8. 91_civic_si
    Wasilla, Alaska
    You are going to need different spindles for that swap also. Get some from a dx, si, or ex model civic
