First swap questions
Discussion in 'Civic and del Sol - EG and EK' started by tehjrow, Mar 11, 2010.
  1. tehjrow
    tehjrow New Member
    Hello. I have owned and done work to a lot of Hondas. Currently own a 1997 Prelude and a 2001 S2000.
    I want to do a swap (my first). I want to start with a very easy swap.
    I'm looking for suggestions on a car/motor to do that doesn't require a lot of extra wiring or converting from OBD1 to OBD2.
    I was thinking 92-95 civic hatch and put a B16A in it. From what I have read so far that is about the easiest swap to do. Does this sound right?
    Thanks
  2. civichatch1988
    civichatch1988 Ef hatch
    Seattle
    Yeah as long as the car is already setup for vtec if not all you simply do is run a wire for vtec
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Yup. B16A into 5th gen Civic hatch is a piece of cake.
  4. BrutalB83
    Rochester Hills, MI
    H22s into 90-97 Accords are very easy swaps as well...
  5. damien360kl
    damien360kl New Member
    how hard would it be to take out my d16 out of my 89 teg and putting in a b18a1 or b18b1? what do i need for these swaps?
  6. pro716
    pro716 New Member
    Easiest swap to do 92-95. Can be done in few hours and a case of beer.
  7. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Depending on which b16 swap you purchase (obd1/obd2), its easy. If you DO buy an obd2 swap, converting it to obd1 is pretty easy also. obd1 swaps can be cheaper also.
  8. BrutalB83
    Rochester Hills, MI
    It's not that horribly difficult. Check out Hasport's website. They have the mount kit you'll need and instructions. One thing to note though, it's mandatory that you lose either power steering or A/C for that swap (can't remember which)...
