Okay, so most or all of us drive hondas here so as a result most of us have been faced with the rust problem over the wheel well in the rear quarter panels. I just want to know how you guys specifically fix them.
The rust on the back of my sol has gotten pretty bad, to the point where it basically should be torched and cut out, then replaced with a new piece of panel BUT since the sol is a unibody and you can't just remove the rear quarterpanels that will be damn expensive.
I was going to grind the rust off with a metal grinder [obviously] and then just fill it up with bondo, what do you guys do?
