then you see that car in real life and talk to the owner and realize it has 400 lbs of extra entertainment and unusable shit and it only makes a little over 400 whp and it runs a high 13 and you lose all faith you still had left after seeing the terrible film known as fast and the furious. (but you still see the next three for some reason in hopes that it will change, but then they swap an rb26 into a junked mustang and paint it over night and you puke again)then u get a ragedy supra and turn it in to a 10 sec beast.
hit the rev limiter count to 10 then shift
yes this works for all the gears
for launch just hold the clutch and gas pedal to the floor when it hits the rev limiter count to 10 and dump the clutch, this will get you your best possible launch (this is the trick the magazines use to get their test results)
if you find you are getting a lot of wheel spin when launching like this, you need to warm up the tires more... for a FWD car the best way to do this is to put it in reverse, cut the wheel all the way to the right or left, stomp on the throttle using the same rev limiter 10 count that you want to use for the launch, then dump the clutch and count 10 full revolutions of the car, when finished turn the wheel the other way and repeat the process... after this your tires will be properly warmed up and you should get a sweet launch
if you are still spinning a lot on the launch you may need a wider and softer tire
