flywheel
Discussion in 'Engine Building' started by rico2001, Nov 3, 2002.
  1. rico2001
    rico2001 Member
    anyone know a site for factory honda flywheel weight.
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    What flywheel do you have?
    I don't know a site, but I know a few weights.
  3. rico2001
    rico2001 Member
    well i have a f22a6 (92 accord ex). i'm looking in getting a lightweight flywheel and i want to know about what i should be looking for. so far i have found a few 6 lb. ones.
  4. chet
    chet Senior Member
    st petersburg, florida
  5. rico2001
    rico2001 Member
    oh sorry i found a few 8 lb. ones
  6. pissedoffsol
    thats still insanely light.....
    11lb is a light one...
    the lighter you go, the less streetable it is--
    meaning not only will it accelerate faster, but there will be no momentum to keep you crusingin- ie 4th gear, you let off, you'll be down to 20 mph before you know it
  7. stpracer
    stpracer Senior Member
    Grove City, Pa.
    I have a 7.5lb one in my daily. Seems ok - or maybe I just don't notice it. - Now the six puck clutch on the other hand!!!!! I do notice that!!!!!
  8. rico2001
    rico2001 Member
    ok thanx for that info guys but back to my original ?
  9. phunky.buddha
    Dallas / Fort Worth, TX
    Not true- my 8 lb flywheel is totally streetable. It still takes quite some time to drop speeds in 4th gear... now when you let off the clutch, that's another matter. The revs still don't fall fast enough for me though- maybe I shift too fast.
    :D
  10. rico2001
    rico2001 Member
    ha Calesta, whos flywheel do you have and how was it to install.
  11. phunky.buddha
    Clutchmasters- which is the same as the aluminum rebuildable Fidanza flywheel. I had it installed when I changed my clutch... easy as pie.
  12. rico2001
    rico2001 Member
    I saw a Fidanza flywheel for my car for $325, is that a good price or not?
  13. phunky.buddha
    That's about retail.. not bad, not the best. It's cheaper than what I paid though. ;)
