#1. Remove Fuel Return line from FPR.
#2. Attach Fuel Return line you just disconnected to the OUTLET of the FMU.
#3. Take new section of hose, and run it from OUTLET of FPR to INLET of the FMU.
#4. Cut FPR Vaccuum line and install a T.
#5. Run Vaccuum line from T that you just installed to the vaccuum port on the FMU.
#6. Mount FMU to firewall.
#7. Check all hose clamps to make sure they are tight.
#8. Boost.
