After listening to your replies on whether or not I should build my current h23 for boost or buy a h22, I have decided to keep the h23 and start buildin it up.
I want to make a ridiculous amount of power, so now I'm askin what is reccomended for specifics when buildin this engine up for boost.
How much of an overbore is ideal?
Should I change the compression rating?
Should I do anything to the crank?
Is a stroker kit reccomended?
What pistons should I go with?
Should I swap out the rods? (i've heard the stock ones can handle 400hp)
What Camshafts should I use? ( I've expressed some interest in WEB regrinds, but ????????)
Valves?
Lifters?
Springs?
I could go on, but basically I'm askin what is the best combination and what do you think I should do exactly?
Thanks
Valves?
Lifters?
Springs?
Thanks
