Scorchin Civic
I am in no hurry to sell these items so if your looking for a hand out or thinking about low balling then look some where else.
Complete AC system that’s from my 1992 Honda Civic Si, asking $150. This will included everything that will be found under the hood. This is still all bolted up so you will even get all nuts & bolts that are removed as well. Will not be removed until a deposit is placed or paid in full.
Complete D16Z6 swap that’s from the same running Civic, asking $750. Runs with no problems and still gets 30+ miles to a gallon. Needs some gaskets changed cause it leaks oil from the valve cover, possibly the v-tec solenoid gasket as well. Swap will not be removed until a deposit is placed or paid in full. Listed below is what all will be included with the swap.
Motor
Transmission
Distributor
Engine Harness
P28 ECU
Axles
Shift Linkage
Exhaust Manifold
You are more then welcome to come see the parts and hear the motor run and or test drive the swap. Please understand that if you make a deposit and pull out of the deal then you will not get the deposit back.
Motor
Transmission
Distributor
Engine Harness
P28 ECU
Axles
Shift Linkage
Exhaust Manifold
