more info. What kind of ECU was in there, what kind is in there now. When you say won't start, what kind of symtoms? Doesn't even crank? Just cranks and never fires?
However, chances are your nuetral safty switch is not hooked up. you can simply just have the circuit always closed, but then you can start it even with the car in gear, without using the clutch.
