Accordturbo94
I have a question... I dont ever get a response so I will try one more time! I did my h22 swap in my accord! When I started it for the first time I got a check engine light... it was my intake temp sensor, idle control valve, and map! I knew I would get the first to because I didnt have them hooked up... so i quick hooked them up! Now only a map code was showing! Well I knew I had the map hooked up right and tryed both the map that came with the h22 and on the accord f22! No luck still showed it! So i tryed my other ecu and it didnt give me any codes! But didnt run right... I tryed the other ecu I Originaly had on and it wouldnt give me any codes! Now none of the ecus show codes! I can even unplug sensors and no codes! I ord a new ecu... but want to make sure I dont fry this one.......... Are they fried and did I do something wrong! I know the wires are ok!
