From D16Y8 to H22A
Discussion in 'HYBRID -> EG-EK / DC' started by DwnShftPrincess, Jun 5, 2005.
  1. DwnShftPrincess
    DwnShftPrincess Senior Member
    Orangeburg, SC
    I am wanting to purchase a H22A motor for my 96 civic. My transmission has 292000 mile, is grinding in 3rd (rarely) and I have a problem shifting down, I usually just get stuck in neutral (once or twice every two weeks). I don't think thats too bad for the miles but I just want to swap it out completely.
    Here is what the H22A comes with
    » Jdm motor
    » Jdm transmission
    » Distributor, Jdm ECU
    » Complete Intake Manifold
    » Alternator
    » A/C Power Steering Pump
    » All Brackets and Sensors
    www.naganojapanese.com
    I know about the axles and ekh1 mountings. What else is there.
    Looking to get started within the next month.
  2. nismogod
    nismogod Senior Member
    Deltona, FL
    can i have your old motor? :-D
  3. DwnShftPrincess
    Orangeburg, SC
    Whyyyyyyyyyyy? :eek: It has about 85-95K on it but whyyyyyyyyyyyyyyy? :eek:
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Are you kidding? 85,000 miles isn't even broken in yet.
  5. reckedracing
    reckedracing TTIWWOP VIP
    NY
    if the motor only has 90K then why not just swap in a d series tranny, and get a limited slip installed while you;re at it...
    you're also gonna need an accord/prelude shifter(in car) and the shifter cables...
    i suggest you check hmotorsonline.com for the motors, everyone says they are the best source...
    and check hasport.com and look at the mount kit instructions for a better idea of whats entailed in this swap...
  6. nismogod
    Deltona, FL
    i want the motor to build a d-series turbo. everything inside would be swapped out anyways. :-D
