Quoted post[/post]]
Well, now that the Primer is there, I see blue through it too. The primer should be even applied, and then used as a guide coat for sanding. Grab some brighter primer, give it a good once-over and sand all of the primer off in large, sweeping horizontal strokes front to rear. Using an 800 grit or more, don't finger-rub it or lift the block.
The paint will glide onto the body and you'll find yourself doing less finish sanding afterwards.
