front and rear mount
Discussion in 'HYBRID -> BA-BB /CA-CD' started by amraccord94, Jul 28, 2003.
  1. amraccord94
    amraccord94 Junior Member
    the swap is a h22a1 into my 94 accord lx. I got everything in the only thing left is the front and rear mount. the dam thing don't line up. Im using my accord mounts do i need the prelude mounts. what am i doing wrong?
    what do i do.?????????
    im going by the instruction i found on a site. let me tell you im have a bone na pick with them when im done here.
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Ummmm, I used my Accord mounts for the passenger side, front and rear. I know for a fact that it works. The order I did it in was passenger, front, rear, driver. Try that and see if it works.
  3. 90 accord
    90 accord Chicks dig the box Moderator VIP
    Mesa, AZ
    it's doesn't. not don't.
  4. amraccord94
    ok i tried it, but know i cant put in the driver side and front mount. the passinger and rear mount is in but the front and driver side mount dont fit???? was i suppost to grind down just one side of the driver side mount??
  5. dohcvtec_accord
    The left lane
    I think it was just one side, but I'm not sure. I did it the other way, using half a driver's side Prelude mount and half an Accord side mount.
    If you're using stock Accord mounts, the front, rear, and passenger side should bolt right in....
  6. amraccord94
    the only prelude mount im using is the drive side
  7. dohcvtec_accord
    The left lane
    I don't know what to tell you then, man. Post up some pictures? Make sure the mounts are installed correctly? Get a BFH? :)
  8. amraccord94
  9. dohcvtec_accord
    The left lane
  10. amraccord94
    ok did that.
    can i go with out a front mount or is it a must that it has to go in.
  11. dohcvtec_accord
    The left lane
    Definitely without a doubt use all 4 mounts.
  12. amraccord94
    ok i got the driver side mount in with some grinding. but it fit loosely just might need washers.
    i just have the front mount now, have any suggustions on what to do.
  13. dohcvtec_accord
    The left lane
    Did the mount get bent/deformed somehow?
    Did you completely tighten the bolts on the other mounts? Maybe try just setting the mounts in place and wiggling the engine around to make the front mount fit?
  14. amraccord94
  15. amraccord94
    ok i got it in but had to use the accord front bracket.not the prelude.
  16. dohcvtec_accord
    The left lane
    You mean for the front motor mount?
  17. amraccord94
    no i mean the accord front bracket and mount.
  18. dohcvtec_accord
    The left lane
    Ummm, I thought that's what you were doing all along. Here:
    Front: Accord bracket and mount
    Passenger: Accord bracket and mount
    Rear: Accord bracket and mount
    Driver: Either grind down the Accord mount, or use the Prelude engine-half and Accord chassis half
    Did the website you were looking at not say this?
  19. amraccord94
    what i did for it to work is:
    accord tranny mount
    prelude driver mount, grind down like hell
    accord rear mount with prelude bracket. accord rear bracket didn't fit the h22 tranny.
  20. dohcvtec_accord
    The left lane
    Strange. I used my stock Accord rear mount and bracket.
    Also, don't you mean the H22 block, not tranny? I'm pretty darn sure the rear mount bolts to the block....but it's been awhile since I did the swap.
