front camber adjustment kits
Discussion in 'Wheels / Suspension / Tires / Brakes' started by breakdancingbob, Aug 16, 2005.
  1. breakdancingbob
    breakdancingbob Member
    I just got some front camber adjustmet kits for my 90 crx. Anyone know where I can find some installation directions.
  2. imnot4n
    imnot4n Junior Member
    I might be able to help you out.
    But, which type of front camber adjusters did you get..
    Upper control arms?
    Ball joints?
    Shim kit?
    Toe adjuster?
    Pillow ball?
    etc
  3. breakdancingbob
  4. CiViC_SOHC
    CiViC_SOHC Senior Member
    most likely skunk2 right? ok well anyways if so! what you do is there is two bolts on your shock tower...they are towards the inner part of it..(still on top) remove those two bolts..take the upper ball joint out.take the control arm OFF put the new control arm on...and it should be adjustable by you pulling or pushing on it the way you need it...there is an article somewhere but I can't find it....but its not that hard...
  5. CRX-YEM
    Wallingford, CT
    since when does skunk2 make upper control arms for a crx ??
    I thought they were only for the Honda Civic, Del Sol 1992-1995
  6. CiViC_SOHC
    didni't know if they had ones for CRX or not all I know is they had them for my car :)
