Front end change
zachballa_07
im wanting to convert my eg to the 96 year....i kno i have to change the fenders,hood,healights,bumper.... i was told the other day i had to change the doors to is this true???
Check the fender line on an existing EK, then match it up to the door on your EG. Hell, get a giant piece of butcher paper and trace it out on the EK, then lay it on your EG. Easy. Then you'll know if you have to cut and weld.
When cutting and welding is required though, you're usually splicing the back end of your original fender with the front end of the new fender. That way you're guaranteed to match the original door line of your car.
