EGProject
YEEEEAAHHHHH
Allright, I have an EG Coupe - and the previous owner had a low-speed collision with a minivan. This accident managed to push the center of the hood in a little bit, and along with it, the latch, and a a tad bit of the core support. One of my friends who does body work has looked at it, and theres nothing really wrong with either the front-end alignment, or the core support as a whole. The only real difference is that the hood is done for - I know that, and I am looking for a used one - and that the latch is useless.
I am faced with two options when I get my new (used) hood.
1) Ditch the latch alltogether, remove it, and use a hood pin kit. Only drawbacks would be is a slightly stupid appearence (pins on a stock hood).
2) Get a good latch (used) and attempt to pull the latch mount out a bit to get the hood to latch tight.
As a note, when I got the car, the hood would latch - but only engage the safety lock, not lock tight.
The big problem with pulling the latch mount is that a) odd location, and b)getting it to fit just right.
Is it worth the trouble, or should I go for the $40 solution with hood pins?
P.S. If anyone knows of a decent website concerning slavage part, please post it here. Ebay does not appear to have any used white EG hoods, and OEM is $160.
Thanks.
Thanks.
