Front sway bar options
92CHB
I am looking into putting a front sway bar on my 92 dx hatch and am looking for peoples opinions on whether to go with the ITR/GSR bar or an EG Si one. I currently have a rear 23mm ITR sway bar with an ASR subframe brace on the car . I have read that if i go with the Si one i will have a more "neutral" feel to the car, where as if i went with the ITR/GSR one it will promote more oversteer causing the ass end to come around. I am just looking to tighten up the front via swaybar. I'd figure the ITR/GSR one to match the rear but i could be completely wrong:confused: Thanks for any help or opinions!
I have a GSR front sway bar and an ITR rear 22mm bar and it is great. I auto-x and the car is pretty dang neutral. sometime it will push a little and sometimes I will be wagging my trunk back and forth.
I believe the GSR is a 24mm... what size is the SI bar?
