FROZEN COOLANT!!!.....help
Discussion in 'Accord' started by JDMchic, Jan 29, 2010.
  1. JDMchic
    JDMchic New Member
    New York
    Ok...when I started my car this morning it was kind of loud, as temp increased the RPM started going crazy. Popped the hood to find my radiator was full of green slush! I had asked a friend to add some anti-freeze the other day since it was a little low, only to find out they added water by mistake! Guys help me out, whats the best way to get this unfroze?
  2. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    better hope you didnt crack your block
  3. TurboMirage
    best way is to pour some boiling hot water in there and hope for the best.
  4. DESPAIN
    flower mound TX
    Or boiling hot anitfreeze!
  5. prpprimo
    prpprimo Hondaholic
    ABQ
    Just wait for it to thaw. :eek:
    Why risk any further damage?
  6. DESPAIN
    flower mound TX
    But if it frezzes more.....there could be more damage?
  7. JDMchic
    JDMchic New Member
    New York
    Yea...I def dont want it to get worse. Right now its like slush. The temp this morning was 16 degrees, going up to 47 today, but tonight will go below freezing again. Someone told me to put some hot coals under the engine to slowly warm the block. Should I even attempt this?
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
    I assume you don't have a garage? If you do, put a space heater under the car and warm up the engine that way. May have already toasted the water pump..
    If you don't have a garage, Use the space heater and a tarp or something.. Close the hood, seal off the engine bay from wind with the tarp, and warm up the engine.. Just use common sense and don't burn your car to the ground.. Give it long enough to get the whole block kinda warm, then drain that garbage and put fresh, properly mixed antifreeze in it. I wouldn't start the car again until you know you've got it all thawed.
    Once done, double check for any coolant and oil leaks to make sure there are no cracks or damaged seals.
  9. prpprimo
    prpprimo Hondaholic
    ABQ
    OK the next common sense part is, once its thawed.
    "drain and refill with antifreeze"
    Also, dont forget to wipe once your done. :eek:
  10. civic94cpe23
    civic94cpe23 New Member
    Your block will probably be ok... ive had it happen on my 4x4's. Good thing you found out though otherwise by the second day it probably would have been solid. Goodl uck.
  11. Briansol
    let the car run with the cap open...
    squeeze the hoses and let some stuff spill out.
    top is off with straight unmixed prestone/etc
  12. Ethan
    Ethan Well-Known Member
    +1 i had this happen to me except... i had pure water in my whole system. if its too frozen you can put an electric heater under the car to slowly warm it up and then let it run.
  13. 34diesel34
    34diesel34 Import Tuner
    USA
    Pour some boiling water in the coolant system an flush it out completely. Then refill with new coolant. This is why you dont let anyone touch your car. Especially if they dont know what the hell they are doing. He dont give a damn about it. If your engine is fucked up from this it's your problem not his. He probably thinks that shit is funny.
  14. JDMchic
    JDMchic New Member
    New York
    Just an update: Block was fine, changing the radiator in a few minutes, started leaking
  15. Ethan
