frustration
Discussion in 'HYBRID -> ED-EF / DA' started by Airgetcha, Jul 12, 2004.
  1. Airgetcha
    Airgetcha Junior Member
    88 CRX Si with B16A P30 ecu. I am a poor man, so I spliced wires to the ecu. I used 3 different references to confirm ecu pin outs. So, the motor will turn-over and the fuel pump will buzz but no spark. Here's some trouble shooting I have performed up till this point.
    1. replaced ignitor with known working ignitor.
    2. checked #32 fuse and is good.
    3. checked for battery voltage between black/yellow wire and ground. ok.
    4. checked for battery voltage between white/blue wire and ground. ok.
    7. checked for continuity between ignitor body and distributor housing. ok.
    any help will be appreciated.
    Thanks airgetcha
  2. RSBAD454
    RSBAD454 Member
    back up here Turbo.......i read you are using a P30 OBD-1 ECU in your 88 Si? did you do a non OBD to OBD-1 conversion?
  3. Airgetcha
    I converted to OBD-1 by splicing wires as best I could. I realize this is most likely the problem, but I followed reference material closely.
    ECU Pinouts
    p30_obd1
    A1 BRN INJ1 INJ1
    A2 YEL INJ4 INJ4
    A3 RED INJ2 INJ2
    A4 ORN/WHT VTS VTEC solenoid
    A5 LT BLU INJ3 INJ3
    A6 ORN/BLK PO2SHTC O2 sensor (heating element)
    A7 GRN/YEL FLR1 fuel pump
    A8 (empty)
    A9 GRN/WHT IACV IAC valve
    A10 (empty)
    A11 (empty)
    A12 YEL/GRN FANC Fan Output
    A13 GRN/ORN MIL MIL (check engine light)
    A14 (empty)
    A15 BLK/RED ACC (a/c compressor clutch)
    A16 WHT/YEL ALT C alternator
    A17
    A18 (empty)
    A19 (a/t trans only)
    A20 RED PCS EVAP purge control solenoid
    A21 RED/GRN ICM ICM
    A22 (empty)
    A23 BLK PG1 ground
    A24 BLK PG2 ground
    A25 YEL/BLK IGP2 to main relay and to gound for o
    A26 BRN/BLK LG1 gound
    B1 YEL/BLK IGP2 to pin A25
    B2 BRN/BLK LG2 ground to shields for CYP & TDC
    B3 (a/t trans only)
    B4 (a/t trans only)
    B5 BLU/RED ACS a/c switch
    B6 (empty)
    B7 (a/t trans only)
    B8 BRN/RED PSPSW PSP switch
    B9 BLU/WHT clutch interlock switch
    B10 YEL/BLU VSS vehicle speed sensor
    B11 ORN CYP P CYP -P
    B12 WHT CYP M CYP -M
    B13 ORN/BLU TDC P TDC -P
    B14 WHT/BLU TDC M TDC -M
    B15 BLU/GRN CKP P CKP -P
    B16 BLU/YEL CKP M CKP -M
    D1 WHT/BLU VBU Back Up Power
    D2 GRN/WHT BKSW brake switch
    D3 KS Knock Sensor
    D4 BRN SCS service check connector
    D5 (empty)
    D6 ORN/BLU VTM VTEC pressure switch
    D7 LT BLU TXD/RXD (data link connector)
    D8 (empty)
    D9 PNK ALT F alternator
    D10 GRN/RED ELD electric load detector
    D11 RED/BLU TPS TPS Signal
    D12 YEL/GRN
    D13 RED/WHT ECT ECT sensor
    D14 WHT PHO2S O2 sensor
    D15 RED/YEL IAT IAT sensor
    D16 WHT/YEL VREF VREF
    D17 WHT MAP Map Signal
    D18 (a/t trans only)
    D19 YEL/GRN VCC1 MAP 5V
    D20 YEL/WHT VCC2 TPS 5V
    D21 GRN/BLU SG1 MAP GND
    D22 GRN/WHT SG2 TPS GND
    ECU Pinouts
    pr3_a
    A1 BRN INJ1 fuel injector control # 1
    A02 BLK PG1 Ground
    A03 RED INJ2 fuel injector control # 2
    A04 BLK PG2 Ground
    A05 LT BLU INJ3 fuel injector control # 3
    A06 GRN purge cut-off solinoid valve
    A07 YEL INJ4 fuel injector control # 4
    A08 VTS VTEC solenoid
    A09
    A10 Pressure Regulator Cutoff Soleno
    A11 BLU/YEL IACV from electronic air control valv
    A12 GRN/BLK FLR1 fuel pump control
    A13 YEL/BLK IGP1 power Input
    A14 GRN/BLK FLR2 fuel pump control
    A15 YEL/BLK IGP2 power Input
    A16 BRN/BLK ground
    A17
    A18 BLK/RED ground
    B01 WHT/GRN VBP Battery Backup
    B02
    B03 YEL ACC a/c compressor clutch relay cont
    B04 FANC
    B05 WHT/YEL VTM VTEC pressure switch
    B06 GRN/ORN MIL check engine warning light
    B07
    B08 YEL/GRN ACS a/c on input
    B09
    B10 ORN CYP P crank sensor (1)
    B11 Fuse Box
    B12 WHT ? CYP M crank sensor (2)
    B13 BLU/WHT starting input
    B14 BLU ALT alternator output signal
    B15 WHT ? ignition output signal
    B16 YEL/RED VSS VSS
    B17 WHT ? ignition output signal
    B18
    B19 KS Knock sensor
    B20 BRN SCS ignition timing adjusting connec
    C01 BLU/GRN CKP P CYL sensor (1)
    C02 BLU/YEL CKP M CYL sensor (2)
    C03 ORN/BLU TDC P TDC sensor (1)
    C04 WHT/BLU TDC M TDC sensor (2)
    C05 RED/YEL IAT intake air temperature sensor
    C06 RED/WHT ? ECT coolant temperature sensor
    C07 RED/BLU TPS throttle angle sensor
    C08 O2S Dual O2 Sensor (JDM)
    C09 RED/WHT ? PA atomosphere pressure sensor inpu
    C10 GRN/WHT ? BKSW brake light switch
    C11 GRN/WHT ? MIL ground
    C12 GRN/WHT ? SG2 TPS GND
    C13 YEL/WHT VCC1 TPS 5V
    C14 SG1 MAP GND
    C15 YEL/RED VCC2 MAP 5V
    C16 WHT O2S oxygen sensor
    if this reference material is incorrect please let me know.
    also, I can crank the engine over without the ECU connected. should I be able to do this?
    Thanks Airgetcha
  4. RSBAD454
    RSBAD454 Member
    i have yet to do this swap.....but did you use a jumper harness between ECU and Carside harness? did you wire Dizzy connector correctly?
  5. 4gCRX
    4gCRX Junior Member
    Check all of your grounds, plug gap (.039-.043)...
  6. Airgetcha
    Jumper harness?.....not sure what that is, but what I did do was use my old harness from the 88 Si. Spliced it to the distributor plugs that came with the new engine. Did I connect the wires correctly, problably not. I just spliced the same colored wires to the distributor plugs. If anyone has any idea's on this please let me know. I have not been able to fined a list of color coded wires for a PM6 ECU.
    I realize its obdo, but are all obdo ECU colored wires the same? Also, I inadvertently shifted the distributor when I took it apart. I understand this will advanced or retard the timing, but will it prevent spark?
    while troubleshooting a coolant leak I found the ground to thermostate housing disconnected. I connected it and still nothing. The next thing I will try is checking for voltage to the ecu pin#a25, I believe this is the ignition power.
    symptoms: every time I crank the engine over I can smell fuel, but no obvious leaks that I can see. I pulled a plug and grounded it and had the engine turned over. I saw spark twice but could not consistently reproduce it suggesting this was static buildup?
    Thanks
    Airgetcha
