WI FS: 1987 Acura Integra LS in Wisconsin $995 obo
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by esi42, Jan 9, 2011.
  1. esi42
    esi42 Member
    1987 Acura Integra for sale. The price has been reduced for a fast sale. Got a new car already and would like this to be sold asap. Asking 995 obo. I have twice that amount in parts alone invested into the car. Cheap transportation, come get it. Gets around 35mpg similar to civic or crx and is also fun to drive. Not loud at all, drives stock. I'd take it anywhere. Drive this one home unlike other cars of similar price. Body has some rust but its a good runner. Good glass, clean title. Good daily driver, work vehicle, or winter car. I put a lot of work into the car as you can see from the list below. I have more pics that I'll add later.
    Make: Acura
    Model: Integra
    Trim Level: LS
    1.6L Dohc Engine 119hp
    Color: Silver
    Mileage: 180,000
    Has sunroof and tach from the factory
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    88 Blacktop D16a1 Engine
    Dohc ZC cylinder head with valve job/resurface, new valve stem seals and oem headgasket (from JDM honda civic)
    Dohc ZC Intake Manifold (from JDM honda civic)
    New timing belt, water pump, tensioner, thermostat, all new gaskets
    Powder coated Red valve cover
    K&N air filter and short ram intake
    Ebay d16 header and good oem exhaust
    Converted from vacuum advance to electronic advance using a Pg7 Ecu (88+ obd0)
    Parts replaced within the last 15,000 miles:
    5 spd manual transmission swap with new clutch kit
    Manual steering rack from 1987 Crx Si with new outer tie rods
    New o2 sensor
    New heater blower motor
    New alternator
    New radiator
    New master cylinder
    New front rotors/pads/calipers
    New rear pads
    New front struts
    New outer tie rods
    New Lower control arms/balljoints
    Energy suspension lower control arm, sway bar, and shifter bushings
    Has 14" Dunlop Graspic snow tires on steelies but they are getting low on tread
    I've tried to make description as accurate as possible and any other questions can be answered in person when you test drive the car. Serious buyers only please. If you aren't going to buy, please don't waste my time.
    Pm here or call me at: 6 zero 8 - 6 zero 4 - 9 zero 19.
    Thanks
  2. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    It'd be a good car to use for the swap and part out. Or drive the piss out of. Good price. GLWS.
  3. eg6sir
    Good winter beater w/ snow tires already
