FS: 3 chipped p28's
Discussion in 'Parts: For Sale/Trade/Wanted' started by projekteg, Mar 29, 2005.
  1. projekteg
    projekteg Senior Member
    like it says, i have quite a few p28's (only have three of them chipped ready to go right now). 120 shipped with a basemap of your choice for any engine. can be programmed for sohc, dohc, vtec, or non vtec, boosted, or n/a. i can put a completely stock untouched p28 rom on the chip and it will be just like stock, or i can program a basemap to your likings with altered settings such as vtec, speed limiter, rev limiter, etc. i have quite a few vouches on here, and tons on homemadeturbo.com. pay pal verified and also accept money orders and personal checks. also has the 4 pin header soldered in at cn2 for data logging, and i sell serial data logging cables that plug right up nice and neat, only 20 bucks extra if purchased with the ecu!
  2. chap_e77
    chap_e77 Member
    ttt
  3. david_jones001
    david_jones001 Senior Member
    Arizona
    hey, how much whould u charge for a p28 wiht uberdata, and bbk's tuned map as a basemap. and install a 4 pin header for later dataloging
  4. ryan89crx
    ryan89crx Senior Member
    Washington State
    bump for a great seller!!
  5. projekteg
    all of my chipped p28's with a basemap and 4 pin header are always 120 shipped, you should know that, you're on HMT a lot ;)
  6. projectxspeed
    projectxspeed Senior Member
    New Hampshire
  7. projekteg
    yeah, i don't have the ability to to program the ecu to switch between two programmed maps. uberdata does have a script that will activate a nitrous solenoid, but it doesn't switch to a seperate map 'yet'. so you would basically have to have two chips, one for when you were spraying that had modified fuel/ign. maps when nitrous was engaged, and one for not spraying, although you could drive on the n2o map without spraying with no harm, just might lack a little power from pulling timing at wot.
  8. projekteg
    i'm not sure if you're capable of running two seperate maps with a vafc or not, i personally don't like them and haven't messed with them any more than some simple fuel corrections on the dyno. i do however know that you can't tune your ign. with them, which is the main thing you want to be able to tune for nitrous, so it would be pointless. you could retard your timing at the distributor, but then you'd be losing power all over, so you'd be better off with the first option i gave you if you were going to do that.
  9. david_jones001
    Arizona
    how much do u charge extra for the bbk tuned basemap tho
  10. PhyRe
    PhyRe Senior Member
    ct
    [QUOTE]120 shipped with a basemap of your choice for any engine[/QUOTE]
    um.....im just gunna take a shot in the dark but im thinkin some where around 120? and i bet you if you ask real nice, for another 20, you could get the dataloging cable thrown in there too. but hey im not selling it im just takin a lucky guess.
  11. projekteg
    [post=481403]Quoted post[/post]​
    [/quote]
    good guess ;)
  12. projekteg
  13. bigpigpoppa
    bigpigpoppa Junior Member
    Can you make a Stock Map for a OBD1 P72 that is socketed and have it run the stock maps for a OBD1 GSR. I also have a P28 dont know if you can make it run stock p72 maps or not if you can let me know. Thanks man.
    J
  14. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    where did you get that wire from?
  15. pissedoffsol
  16. projekteg
    yes and yes. the p72 will obviously run a stock gsr map, since that's what it is for, and the p28 can run the map, but requires extra components to get the iab's functioning and will not have the knock sensor. if you have a p72, you'd be better off using that.
