FS: 90' CRX B18a1 swap. 1200.00!!
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by crxmatt, Aug 9, 2007.
  1. crxmatt
    crxmatt New Member
    I've got a 90' CRX DX good title w/ a 93' Teg B18a1 (60k on motor) converted OBD1 to OBD0) swap . Chassis has 150k on it, Engine runs great, will fire right up no problem, 4-1 header, new axles, mounts, rear located new battery with all new heavy guage grounds and power wire. Body needs some attention (a little rear well rust, door rust, and one front fender needs replaced.. and I can't figure out the shift linkage thing to get it to shift right. Could be transmission (LS) but the motor/trans were both guaranteed to work when I got them. New clutch as well. Only things the car needs to be driveable is front calipers/pads, and the linkage or a new transmission figured out. I was able to find 1st, 2nd and 3rd gears I believe.
    BONUS: Included are these Motegi MR7 15" wheels w/ tires (low tread)
    1200.00!!!
    I'm in Paoli, Indiana. my cell is 8126531204
