DaBeastWthn
This damn space is 2 shor
1992 Civic LX Sedan....I picked up a new project, a 95 htach. So I'm selling the Fodo with wheels $2200 OBO. It has around 190,xxx miles on it. Located in St Louis, MO area.
*Good*
Interior in excellent condition
All power options work fine
The motor is in perfect condition. It has 190psi compression across the board. It drives and shifts smooth and strong! It's actually pretty fast for the little mods it has.
*New*
Hood
Air Filter
Fuel Filter
Intake Manifold Gasket
Valve Cover Gasket
Oil Pan Gasket
Distributor Cap and Rotor
Ignition Coil and Module
Spark Plugs and Wires
O2 Sensor
Battery
Starter
Shifter Bushings
Left and Right Axles
Front Brake Pads
Clutch
All Fluids Flushed
Regular Oil Changes
*Mods*
D16Z6 Intake Manifold
D16Z6 Transmission
Short Shifter
SS Cat-Back Exhaust System
Adjustable Coilover Springs
Si Front Strut Tower Bar
New inner and outer tie rods
New rear control arms
17" wheels
Full set of 90% tread tires (may or may not come with wheels and tires depending on price it sells for)
*Bad*
It has it's normal minor small dents and dings and needs paint (fading on top and trunk). Normal Honda Rust starting above the rear wheels, but, as you can see in the pics, not too bad yet. Idle surges every so often about a 200-300 swing, not sure why yet because it doesn't do it all the time (could be the TPS or something). But will try to fix before letting it go.
*Good*
*New*
Hood
Air Filter
Fuel Filter
Valve Cover Gasket
Oil Pan Gasket
O2 Sensor
Battery
Starter
Shifter Bushings
Front Brake Pads
Clutch
All Fluids Flushed
Regular Oil Changes
*Mods*
D16Z6 Transmission
Short Shifter
17" wheels
*Bad*
