I have got a crap load of engine parts for you guys today.
The engine parts are off a 1996 integra GSR.
The car was stolen and when I got the car back 6 months later the parts were all in the back (except my block casting and head castings) When the car was stolen it had 65561 miles on it. but the value train (IE cams, values, springs, etc. )only had 55,000 miles on it because I built my head before it got stolen.
Please PM me
Pics are available, also I WILL SHIP BUT YOU PAY FOR SHIPPING
1.) Pistons/piston rings/ rods/rod bearings, and pins
2.) Cut valve cover where you adjust the timing
3.) A stock uncut valve cover
4.) OEM flywheel
5.) Fidanza flywheel-SOLD
6.) Act clutch-SOLD
7.) Gsr/SE rims with tires
8.) VTEC solenoid
9.) Valves/ springs/ keepers/valve seats/and retainers
10.) Oil pump
11.) Oil pan
12.) distributor
13.) Exhaust manifold
14.) Alternator
15.) Starter
16.) Intake manifold
17.) Injectors
18.) Fuel rail
19.) Stock intake piping and box
20.) Idle air control value
21.) Trottle body
22.) Timing belt-SOLD
23.) Timing belt tensoner
24.) Under drive pulley
25.) Rocker arms
26.) Shifter
27.) cam caps and plates
28.)internediate shaft
29.)Stock cams
30.)2 Fat five rims ,no tires
Please name prices if you want.
Thanks Andrew
Please PM me
4.) OEM flywheel
6.) Act clutch-SOLD
8.) VTEC solenoid
10.) Oil pump
11.) Oil pan
12.) distributor
14.) Alternator
15.) Starter
17.) Injectors
18.) Fuel rail
21.) Trottle body
25.) Rocker arms
26.) Shifter
29.)Stock cams
Thanks Andrew
