FS: 97 ls/vtec turbo coupe...chicago
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by sc34dx, Aug 11, 2007.
  1. sc34dx
    sc34dx Junior Member
    FS: 97 ls/vtec turbo coupe...chicago REDUCED!!!!
    REDUCED PRICE....$8500 GIVE HER A NICE HOME!!!
    Due to money problems i am forced to sell my car...i have put in alot of time into this car, but i can not afford to keep it any longer.
    It started off as a 1997 honda civic dx model then i did a si front conversion which included 00 si fenders, hood, bumper,lights and motor...
    last year the car had the b16 turbo'd by whip factory...long story short blew the ring lands on the b16 so i decided to go the safer route and build the next motor...new setup as of today only has 1700 break in miles...so here is the current set up...
    Bottom End:
    stock sleeve b18a1
    golden eagle h-beams
    je 9:0:1 81mm pistons
    ls crank
    clevitte 77 bearings
    new oem water pump
    new oem type-r oil pump
    avid motor mounts
    Head:
    b16a head
    polished valve cover
    cometic head gasket
    golden eagle headstuds
    skunk 2 dual springs
    skunk 2 retainers
    gsr cams
    titan motorsports cam gears
    golden eagle vtec conversion kit
    stock b16 intake manifold and throttle body
    new oem timing belt
    all new oem gaskets and seals
    samco radiator hoses
    Trans:
    stock b16a delsol trans with 4.44 gear
    action clutch stage 4 six puck
    Turbo Set Up:
    inline pro ss polished manifold
    3inch down pipe
    3inch full exhaust
    tial 38mm waste gate
    tial bov
    650hp pte intercooler
    sc61 .63a/r
    custom made catch can
    custom whip factory polished intercooler piping
    all stainless steel braided oil lines
    Fuel:
    pte 1000cc injectors
    walbro 255
    Suspension:
    skunk 2 pro full suspension
    skunk 2 front camber kit
    front upper strut bar
    rear upper strut bar
    Other:
    car comes with si wheels with skunk 2 lug nuts
    turbo xs dual stage boost controller
    plx wideband
    gm 3.5 bar map sensor
    autometer boost pressure gauge
    autometer fuel pressure gauge
    autometer oil pressure gauge
    autometer water temperature gauge
    autometer tach
    momo steering wheel
    turbo timer
    rockford fosgate speakers all around
    8000k hid kit
    Parts not on car but will be included if not sold separate before car is sold:
    2 SPW black racing seats with rails, harnesses, and brackets
    2 15" bronze rota slipstreams with tires
    2 15" polished rota slipstreams with M&H 23x15x8 slicks with only 10 passes on them
    msd sci ignition box with msd blaster coil
    pte 440cc injectors
    rear seats
    brembo drilled and slotted rotors
    the rear of the car is completely gutted, battery was relocated to the trunk...cutoff switch mounted but not installed, the car is tuned on neptune, by dave at whipfactory. right now it only has a base map so that it is drivable with the 1000cc injectors...but all the is needed to make 400-450whp is a final tune by dave....car dose not leak or burn any oil. car has no a/c and no power steering...car is supper light...with the old set up only pushing 300whp i ran a 12.17 at 117mph on only 12psi...so the car moves....!!!
    now the body is a 8/10 i bought it with a small dent in the driver side door that chip'd the paint so the metal is exposed, next the car has a dent in the front passenger fender all that needs do be done is re-tap the holes for the fender and it will be fixed...also car has tiny scratches on the driver side door from some idiot that leaned on my car and scratched it with his belt...other than that the car has no rust...and looks good... car was intended to be a great daily driver and a track monster on the weekends....unfortunately i cannot afford another tune and i lost my job so money is tight... no one wants me to sell it but i cant afford it anymore....couple people on this forum can vouch that this car is well worth it...
    my asking price is $9,500 obo
    everyone knows i am losing alot of money that i invested in it but with 9k you cant build this setup...
    i am not looking for any trades unless it is plus cash
    so guys let me know what you think and post or pm me or call me at
    630-624-8411 my name is erick....thanks i am located in chicago IL.
    here are the only pics i have for right now....but let me know if you need any specific pics i can take them.... picks dont do it justice...
    pics of the dents...first one is not rust its just oxidation...
    [​IMG]in
  2. sc34dx
    Reduced price guys.....bump
