fs: '99 gsr motor parts
saltine
Since I could not find a buyer for my entire setup I will be parting the motor out. Here is what I have for sale. You can contact me at chriscooper123@yahoo.com
‘99 GSR head:
includes: head, valve cover, oil cap, spark plugs, stock valves, cams, vtec solenoid, bolts, rocker arms/ shafts, pins, valve keepers, cam gears, and all nuts, bolts, gromets SOLD
Will fit: 94- 01 b18c engine block, including 97- 01 (itr) b18c5 type r, ctr b16b, 92- 93 b17a gsr, 99- 00 civic si pr3 b16a2, 94- 97 del sol b16a3, as well as ls/ gs/ rs b18a, b18b for lsvtec, and crv b20 (b20a/ b20z) for crvtec, for the frankenstein engine swap.
‘99 GSR short block:
stock bottom end. Has 51,000 miles when removed due to interior fire. Includes entire bottom end from the deck down. SOLD
‘99 GSR 5 speed transmission:
Has 51,000 miles when removed due to interior fire. Has no blow synchros or grinding problems. Worked perfect when car was operational. $500
would you happen to have the starter? and or engine mounts? if so please let me know
thanks
Originally posted by SYPHONSCIVIC@May 26 2004, 07:59 AM
How much for Power Steering Pump, Alternator and starter?
Let em get back to you on that. I don't have a good alternator though...
