94CivicSlow
For SALE in Boston from OBDI B series engine
Crower cams: 2k miles
63402-2
Stage 2 - Road/Rally & Street/Strip.
Most popular for all-motor applications.
Requires #84161 spring/retainer kit.
VTEC controller recommended.
RPM range 1000-9500+.
18-21 hp
405$ Shipped
ACT Street Strip clutch 5k
$220 Shipped
Fidanza 10lb flywheel
95$ Shipped
RC 370CC injectors Saturated 5k mint 200$ Shpped
Unorthodox Cam Gears 100$
GSR OEM Timing Belt 5k - 30$
Forged LS Shortblock 1995 LEGIT 5k
-Eagle H Beams
-Wiseco 11.8:1 hi comp.
-ACL bearings
-ITR Oil and water pumps
-New gaskets
-Had 275 psi comp test when pulled off lsvtec.
Asking: 700 $
SIR B16 head
-Crower .5mm oversized valves
-Skunk2 springs/titanium retainers
-Painted Ford grey
-Comes with cam caps and all bolts
**Needs 1 helicoil on exhaust manifold side 25$ at machine shop
Needs 1 valve guide or valve seal. Leaking around stem top
Burned light oil up top around 8000 rpms
Asking 550$ plus Ship
ARP GSR headstuds 5k
95$ Shipped
Golden Eagle LS VTEC Conversion KitEverything included MINUS the TAP.
Comes with sand plate.
10 an line
AN adapter for head
Allen Plug
160$
63402-2
18-21 hp
405$ Shipped
$220 Shipped
95$ Shipped
-Eagle H Beams
-ACL bearings
-New gaskets
Asking: 700 $
SIR B16 head
-Painted Ford grey
95$ Shipped
10 an line
AN adapter for head
Allen Plug
160$
