Bottom End Info: 00 Si B16A2 81.5MM 8.5:1 Ross Racing Pistons and Rings Eagle H beam rods w/ big ARP rod bolts Golden Eagle block guard ARP Head studs Stock Si oil pump Stock Si oil Pan with A/N fitting for return line Water pump and timing belt have 10k miles on them Main and rod bearings have about 10k miles on them Motor was machined and rebuilt about 10k miles ago, but had to have new piston rings installed about 7k miles later. Head Info: Head b16 head Brian Crower stage 2 boost cams DPR Pure Tuning Springs and Retainers New valvstem seals and head has gone through a machine shop less then 5k on head. Cams and valvetrain never installed. Skunk 2 intake mani New Turbosetup: Greddy big FMIC Less then 5k All Piping included powder coated Blue Real HKS BOV Garret 50 Trim turbo Ram Horn Manifold In great shape Tial 38mm Wastegate Will Come with 2.5 to 3in Downpipe Fuel System Info: RC 1000cc Injectors Aem Fuel Rail Walboro 255 Fuel Pump Transmission and Drivetrain Info: Stock B16 Trans shift great no grinds or anything ACT 6 Puck Unsprung Clutch Less then 7k Stock Flywheel Stock SI Halfshafts Solid Tourqe Mounts B&M Shifter With Linkage Hondata S200 Included with ECU Will come with Axels, Harness everything for a complete swap.. This is a complete swap Built Turbo Set up. The motor made 330Hp at 20Lbs with my old hurt turbo and only reving to 7200Rpm.. Was still making power but do to a wiring issue (wich is now Fixed) it would not rev past that point. I daily drive on this setup and it has treated me well. Asking 4500 OBO. $4500 obo can be shipped for the right rice
