fs b16a with a bunch of extras
hondacivic05
IM PARTING IT ALL OUT im leaving the head on the block so dont bother asking for the head
i have a b16a with
type r cams
ctr crank pulley
skunk 2 cam gears
skunk 2 intake
74 mm throttle body
golden eagle fuel rail
full msd ignition with dizzy
s200 tuned for the b16a
7 or 9 lbs flywheel
stage 2 clutch
tranny has the mixed gears from the ls and sir b16 tranny for the better gear ratio
hasport mounts
pacesetter exhaust
rsr header jdm style
racing cat
rebuilt bottom end
gsr dash with gsr cluster in it working
i really cant think of anything else.....but you would be lucky to get a full b16 swap with ecu axles and everything for 1400 so i think its a fair deal...its sitting in a 89 ef right now... you can have the whole shell i have alot extra parts for it....its not running right now cause the fuel pump is not turning on and the the tail lights turn on when i plug the battery in so it has to be the wiring harness in the car .....if you dont want to pay what i ask then dont buy it....if you want to call me my name is adam and my phone number is 412-401-1511......NO LOW BALLERS.....serious buyers only please....engine has over 200HP civic crx del dol integra civic rsx prelude honda acura b16 b16a b16a1 b16a2 b18 b18a1 b18a2
Hey man, if you decide to part it out let me know. I could use body parts and interior parts. Front fenders, front and rear bumper, The dash, and a few others.
i want the head off the motor dont care about anything else unless u got the b series shift linkage to the car.
i dont care what u want i wouldnt part the head off of a good motor that was a stupid post
Im located in latrobe let me know if you part it out i have a 99 civic that had a b16 obd2 swap ,dad borrowed and blew the motor now i need a new motor for it. tranny axles etc are fine just need the engine
Message me... I'm interested in the motor if willing to sell seperate.
look people im not parting this out the whole swap is in the car....the only way im parting it out if your gonna pay me extra for labor.....its either buy the whole swap for 2000 dollars or leave me alone.....the engine is faster then a type r.....my mr2 has 220 and my civic is just as fast as it
