Syner G Racing LLC
these are new in the box parts
+Blitz super sound dual drive blow off valve ($100)
+hks super sequential BOV Type II (universal) ($225)
+Tial wastegates 38mm (silver) ($ 175)
+Wiseco Turbo pistons K541m815 (for B18C ) with total seal ring kit and wrist pins ($375)
+Top 2005 universal programmer (chip programmer)($75)
+S7 Autotechnic gauges (like defi black outs) oil pressure and A/F ratio($60 for both)
+Greddy Full auto turbo timer ($80)
+Apexi VAFC II($200)
+ARP head stud kit #208-4601($125)
+Uber data kit with extra eeprom and quick release holder.($10)
+IB Spec Rods H beam rods balanced and nitride coated contact surface($275)
+P14 (92 prelude automatic) ecu ($50)
+P28 (94 civic 5 speed) ecu ($100)
+Two Ractive Racing seats with rail kit ($ 400)
+Exedy Racing Clutch HM0225R Multi disc ($1,500)
+Cometic head gasket 81.5mm .030 mls #c4232-030 / 147838 ($75)
+Hondata intake manifold gasket ($30)
+27" x 6.5" x 2.5" intercooler ($150)
+Thermo tech wrap (black #11021 1" x 50') ($50)
+hondata s300 ($500)
+greddy oil catch can 15mm fittings ($50)
+two aem tru time adjustable cam gears 323-802b ($ 225 for both)
+Fluidamper #590601 Street ($325)
+GM 3 bar map #1997152 w/ pigtail ($40)
+GM Boost sensor 12223861 w/ pigtail (from the typhoon) ($25)
+RC pl4-1000cc injectors w/ fuel pressure gauge ($300)
+moroso drag sumped oil pan with pick up ($125)
+Drag 2 1/2" down pipe ($50)
+nology hotwirz & msd wires ($50)
+B series 94 civic intercooler kit (pipes and silcon) ($100)
+wastegate elbow 2 bolt ($40)
+1" dump tube ($ 25)
+drive shaft shop level 0 axels b series to 5th gen civic rated for 300hp w/ intermdeiate drive shaft ($200)
+bag of honda/acura wire harness plugs (some where around 50+) ($50)
+RC 550cc injectors ($275)
+Zietronics zt2 wide band o2 sensor kit ($200)
+proform shift light ($25)
+golden eagel vaccum manifold (blue) ($30)
+2 gauge pod for honda/acura ($10)
+battery box ($ 5)
+turbo smart boost controller (red) ($ 60)
+Tsunami turbo manifold ($250)
+3" down pipe with flex (5 bolt flange) ($200)
+Giant intercooler (havent measured it...takes up whole front of civic) ($125)
+shifter linkage for 5th gen civic to B series w/ short throw shifter with type r knob and energy suspension bushings ($125)
+B18C JDM Type R freshly sleeved with ductile iron 81.5mm sleeves, hot tanked (block is not assembled...everything is tagged and bagged and wrapped with oil soaked rags) its a complete engine minus the pistons and rods. It comes with a brand new rebuild gasket kit and crap load of bearings to get the clearances just right, all accesories like starter, altenator, wiring harness ext. The head has a mild port and polish with omni power titanium valves, ferrera titanium springs and retainers. ($3,500)
I dont ever come on here so if your interested email me at vernon_brandon@hotmail.com. Im located in woodlawn, tn.
I have a couple of turbos for sale also but I'll list those later.
+battery box ($ 5)
