daboosted93
I just put together a full swap for a ef, crx or eg. it is a complete ls swap with long block, intake manifold, either a hydro or cable tranny, halfshaft, both axles, either a obd0 or obd1 ls integra ecu, obd0 or obd1 dizzy, obd0 or obd1 wiring harness. If you are going to put it into an ef or crx, i have a set of nice hasport machined aluminum mounts. it has all new gaskets through out. I will do a compression test if anyone wants one and post the results. will post pics also. if you are interested, please specify what car it will be going into.
complete obd0 swap: 1200
long block
intake manifold
cable tranny
dizzy
halfshaft
axles
hasport mounts
wiring harness
ecu
shift linkage
complete obd1 swap:1100
long block
intake manifold
cable tranny
dizzy
halfshaft
axles
eg/dc mounts
ecu
wiring harness
shift linkage
long block
intake manifold
cable tranny
dizzy
halfshaft
axles
hasport mounts
wiring harness
ecu
shift linkage
long block
intake manifold
cable tranny
dizzy
halfshaft
axles
eg/dc mounts
ecu
wiring harness
shift linkage
