CTR 81.25mm pistons rings and wrist pins, all brand new.------$200 decided to go turbo-----(approximately around 11.6:1 compression ratio if used in gsr with stock head gasket and deck height)
they will fit an ls if you bore it .25 over, i went with the lil bit larger bore so i would have a nice fresh bore to start with. the good thing is that you dont need to re-sleeve the block. but these in an ls will make great power due to the compression ratio.
