goldgreen90ef
goldgeen90ef
whats up, heres what i have...
91 crx si se, 130k chasiss miles. under 100k or less on jdm b16 swap, body clean, good condition, almost no rust, pulls hard, rides ok for a 16y.o. car
the good:::
b16 dohc vtec swap,
no oil leaks, doesnt burn oil
jdm pr3 ecu
knock off type r intake manifold
hasport shift linkage
d.c. sports short shigter
type-r shift boot
air intake w/ aem filter
aem fuel rail
act clutch(low milage under 10 k)
traction bars for crx b16 swap
momo seering wheel
greddy cat back exhaust
header w/ 2 o2 sensors( welded in the right way for pr3 ecu)
test pipe, dnx mid pipe
mugen rear bumper and side skirts(polyurathane)
tokico shocks in rear
brand new monroes in front
tein s tech spings(less than 1 k)
new oem upper and lower ball joints
new tie rod ends
full tune up (wires rotor cap plugs)
new tps sensor
bonnet lift
8 gauge ground wire on valve cover
1/2 inch ground wire on tranny
battery in trunk
maxim 15 inch rims with fuzion 195 50 15 z rated tires, less than 100 miles
keyless entry
the bad::
interior has some pieces not installed(sunroof panel, trying to fix before sale),interior in average condition)
tranny was replaced in feb 06 w a junk yard tranny, makes a whining noise(will throw in a ys1 tranny w deal)
sometimes the throw out bearing whines
rear defrost act upwine
sunroof is not working but seals
FREEBIES ICLUDED IN DEAL... 92 YS1 TRANSMISSION,(STRONGER THAN 90-91 TRANNYS, HAS HYDROLIC INTERNIALS, NEVER BEAT ON, FROM A NON MODDED CAR), BRAND NEW EXEDY CLUTCH KIT,INCLUDES THROW OUT BEARING, PILOT BEARING, DISC AND PRESSURE PLATE, NEVER INSTALLED, BBK 62 mm power plus BBK THROTTLE BODY, AND THE BEST OF ALL....
******JDM SIR-G CAMSHAFTS IN MINT CONDITION READY TO BE INSTALLED****
looking for 92 95 coupes w swaps or who know thanks or 2900$
ill get more pics if any one wants them
the good:::
b16 dohc vtec swap,
jdm pr3 ecu
type-r shift boot
aem fuel rail
momo seering wheel
new tie rod ends
new tps sensor
bonnet lift
battery in trunk
keyless entry
the bad::
