FS/FT Semi-Built B16
Discussion in 'Parts: For Sale/Trade/Wanted' started by mikey bottles, Feb 27, 2011.
Thread Status:
Not open for further replies.
  1. mikey bottles
    mikey bottles Prof. Bottles
    S. Jersey
    Like the title says, FS/FT. Will only trade for 1.6 SOHC VTEC setup, must run and be reliable! I'm back in school and out of work, and I just cant afford to drive 40mi a day, and put premium in this car anymore. Asking $1400 obo/or work out a trade deal. Info about engine:
    OBD-0 B16A
    -Arias 11.35:1 Dome Top All Motor Pistons (81.5mm)
    -King Racing Bearings
    -Supertech Bronze Manganese Valve Guides
    -Supertech Flat Tip Black Nitrided Flat Tip Race Valves
    -Supertech Titanium Dual Valve Springs & Retainers
    -OEM Cams
    -3 Angle Valve Grind
    -Nology Hotwires
    -Skunk2 Triple Ring Cam Seal
    -ACT Stage 3 6 Puck Unsprung Clutch
    -ACT 8.8lb Prolite Flywheel
    -Greddy Timing Belt
    -CTR Crank Pulley
    -Adjustable FPR
    -DC Sports Header
    -ARP Head Studs
    -P28 Tuned By Katman @ JHPUSA
    -Also for sale is the Hasport conversion kit needed to run a cable trans in a '93 Del Sol... may fit other models/years but im not sure. $75 Takes it.
    Build has less than 5k miles on it. I have reciepts for basically all the parts, and for the machine work that was done. It ran strong for me, the only problem I had with it is, it does leak oil out of the right front corner of the head gasket, I replaced it again and it still leaked, both times I used an OEM Honda head gasket and milled the head, not a bad leak though. Any questions pm me on here or contact me at 856 264 6462. Im located in S. Jersey
  2. mikey bottles
    S. Jersey
    Bump!
    1 person likes this.
  3. whit19
    whit19 Ginger Asshole
    South Jersey
    this motor is legit! i can vouch for it! its a complete beast and pulls hard as hell, definitely a motor worth having! :thumbsup:
  4. Finnish EK Racer
    Finnish EK Racer New Member
  5. TurboMirage
    did you use any copper spray on the headgasket?
    that will usually fill the small imperfections in the mating surfaces.
  6. mikey bottles
    S. Jersey
    no i didnt, good trick for the next owner! thanks for the heads up man... updating with pics in like 10 min too!
  7. hondafreak513
    hondafreak513 New Member
    O hi O
  8. mikey bottles
    S. Jersey
    wish i could afford to keep it! noones even interested in this? shoot me some offers folks
  9. mikey bottles
    S. Jersey
  10. mikey bottles
    S. Jersey
  11. whit19
    South Jersey
    bump for a clean legit powerful motor
  12. mikey bottles
    S. Jersey
    apparently nobody wants b's anymore?
  13. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    I already have my b series or I would be all over the swap. where in jersey are you located? im from south jersey cape may area.
  14. mikey bottles
    S. Jersey
    im from the woodbury/national park area... ill miss this motor if it sells.. if it dont sell by the time i go back to work im just going to put it back in with a new trans and some goodies
  15. mikey bottles
    S. Jersey
    Lowered price! Much rather a straight trade for d16z6 setup!
  16. mikey bottles
    S. Jersey
  17. Matts96HB
    Matts96HB . Moderator VIP
    grats on sale, gonna lock this one down to prevent late bumps :thumbsup:
Thread Status:
