frodotoolbox
92 civic si d15b
Cold Fusion Nitrous Kit:
-1 Cold Fusion Nitrous Solenoid
-1 Cold Fusion Fuel Solenoid
-1 Cold Fusion DUAL PURGE solenoid
-1 Nitrous Fogger nozzle
-Jets for nitrous and fuel for anywhere from a 35 shot to a 125 shot
-16 ft nitrous line, near brand new
-10 lb Nitrous Bottle with pressure gauge
-Includes nitrous lines to run from both fuel/nitrous solenoids to the fogger nozzle
-2 (TWO) Nitrous bottle brackets
-Includes all wiring needed, along with the relay you need to hook it up
-Includes WOT switch
I will also include-Nitrous switch/control panel...has purge button, two toggle switches and a power switch controlled by key. This allows you to lock the system when you leave, so that a)it can't be accidentally used and b)so no one can activate the nitrous without your key. The panel has two interchangeable faceplates...one light and one dark.
ALSO INCLUDED I have the fast connect hose connector. It goes onto the nitrous line connecting to the bottle itself. It makes it so you don't need a wrench to tighten or loosen, you can do it by hand!
EVERYTHING IS IN NEAR NEW CONDITION, and everything will be re-tested before shipment to ensure it is in perfect working condition.
For everything BRAND NEW...i spent something like $620. Am looking to get about $475 shipped OBO.
If there are any questions please let me know!
if you want pictures PM me.
