FS:Garage Sale
Just curious, whats is the missing d series link for?
Missing Link is a MAP sensor valve designed for use with aftermarket turbo and supercharged applications. By design, it completely blocks boost from reaching the MAP sensor. It does not bleed boost pressure away from the MAP sensor. Instead, once boost pressure is blocked, it uses the principle of diffusion to equalize with atmospheric pressure to simulate a wide open throttle condition for the ECU. Blocking boost pressure protects the OEM MAP sensor from damage.
